SOLD FS: (WA) Rainbow iPaul DM2000 & iPaul 2.400 Amps
  • 4
qkassidyw
MECP Master Certified
444
Seattle
I have for sale two Rainbow Amps. One is the Monoblock DM2000 and the other is the 2 Channel 2.400. Both are completely functional and the reason I am selling is because I sold my car, got a truck and will be going a different route for the sound system. These are great amps, high sound quality, and they put out a ton of power.
$285 for the 2.400 and $375 for the DM2000 OBO for both. Will use Paypal or local pickup.
Here are the specs for both amps:
# Power Output at 4 Ohms: 360 Watts RMS
# Power Output at 2 Ohms: 730 Watts RMS
# Power Output at 1 Ohms: 1000 Watts RMS
# THD:
# S/N Ratio: >95dBA
# Frequency Response +/- 3dB: 10Hz-250Hz
# Input Sensitivity: 250mV - 6V
# Variable Subsonic Filter
# Low-pass Filter: 50Hz-250Hz, 24dB/Oct
# Current Draw: 90 Amps Maximum
# Dimensions: W x H x D:415 x 60 x 250 mm
Rainbow iPaul 2.400
# Stereo 4 ohm: 2x130 Watt RMS
# Stereo 2 ohm: 2x200 Watt RMS
# Mono 4 ohm: 1x400 Watt RMS
# THD+N:
# Signal-SNR: >95 dBA
# Frequency Range: 10 Hz-35kHz
# Input sensitivity Level In: 250 mV-6
# High Pass/Subsonic - Front: 15 Hz - 500 Hz, 12 dB
# Low pass Rear: 50 Hz - 5kHz, 12dB
# Bandpass Rear: 15 Hz - 5 kHz, 12 dB
# Bass Boost: 0/6/12 dB
# Phase Shifter: 0-180 degrees adjustable
# Remote Control (5m Cable): Level and phase adjustable
# Operating: 11 V-16 V DC
# Weight: 5.8 Kg
Here are the pics of the amps. I only have two mounting feet for both amps but they are still able to be secured (one on either side of the amp) and you can purchase more from Rainbow if needed. Also, there are very minor scuffs that can be buffed out.
Rules say to post a price.
I am local also might be interested if the price is right //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Fixed. Sorry about that. I am in Kirkland, willing to meet in the middle.
First off, seems to me you have the specs backwards. Ignore peak, stick to RMS. Neither of them is going to do great at 60hz, that is really...
qkassidyw
qkassidyw
Seattle
Motovet
audiobaun
    May 19, 2024
1aespinoza
    May 19, 2024
