Fullrange digital amps
mykeys
URABUS
Just wondering if anyone has heard them or used them. I have an install to do in a few months and some of the FD amps have a really small foot print that will come in handy when I have limited space to work with. I have only done minor looking around and havent really got passed the usuall Pioneer and Kenwood versions before I started wondering about the quality (build and sound) or other options.
Mike
Mike
zed audio leviathan. nuff said.
Add the JL Audio HD amplifiers along with the Kenwood XR series to the list!
Harmon/JBL is about to release a set of small, full range, Class D amplifiers too.
Edit: Reading owns me... OP mentioned Kenwood. DOH!
Don't rib me too hard I have been out of the game for a while and all my old crap is still functional so I haven't needed much.. Searching only got me so far and mostly bass amps. So I decided to come back and check the board and again there are a lot of new names and new goodies on the market.
Thanks for the input now for a lil research and see what I can sneak past the wife.
Mike
Buy louisianacrxs sx700.4 //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
why not look at lunar amps? they sound very good and are very small...
It depends on the OP's space constraints. While my Lunar amps do have a small footprint, I have noticed them to be a tad bit taller than most other amplifiers. It is not a problem for me in my particular install, but it could be an issue for someone limited on space.
EDIT: I totally forgot about the new amplifiers that Lunar has for motorcycles. Those would be great for mids/highs and are "digital".
FYI - the kicker's not a class D amp. It's a regular a/b amp with digital front end processing, and it's not small.
I've been running a Lanzar opti4x400d for a year or so now. There is an incoming noise issue that's a problem at low volume, but the amp's not to blame for that. At mid-high volume it sounds great and has never given me a problem.
This is true I did not read that part of the op
Mike
HOLY CRAP YOU GUYS ARE STILL ALIVE lol //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif MY choices would be either the lanzar, JL, OR the arc minis. Not a fan of the alpines, they seem to be a little weak. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
last time i heard a solid class D full range it was decent.. IMO no compersion to say A highend zapco or helix.. now arc and some other use class G and H which are cleaner than D and nearly as efficient as D there just pricey because you need some series feedback to keep things in check...
I use K3b to rip cds and for converting to any file extension I use Sound Converter or Soundkonverter on a Linux machine but you should be able to...
15
That makes sense. I took it apart today. It doesn't look too impressive but it should be better than the head unit. I'm going to install something...
8
I used to have a pair of dd audio redline 608s, for eight inch subs they were very impressive, at least until that ole upgrade bug bit anyway. I...
7
4K
mykeys
URABUS
mykeys
South Prairie, Wa.
Papermaker85
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
