funky amp problems.
wishuponansg
okay, so i have a pretty bottom line amp to begin with. its a power acoustik ps1-5500 'rated' at 3200 watts at 1 ohm (LOFL).
i have it wired down to 1 ohm, and my HDC3 15 just kinda laughs at it, but w/e it was cheap and gets/got the job done. now to the problem: the amp is all of the sudden extremely loud, and i have to completely reset my gains and such everytime it gets loud. it will switch between extrememly loud and normal, sometimes while driving. The amp has held up for about a month, and honestly, sounded quite nice, and was pretty loud (a decent amount of windshield flex).
any ideas whats wrong with it? is it worth getting fixed?
EDIT: forgot to mention, when the sub gets extremely loud, it also sounds extremely muddy, and doesnt play very many upper bass notes.
Possibly the alternator decided to charge? Does it do it when the car is in idle/not running? An extra voltage boost will change the power considerably.
Possibly a RCA issue?
the RCA's are in a pretty tight fit right now, could be that.
most likely //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
if they are pinched, or have an ackward bend in them, or torn, etc etc, that is most likely the culprit.
have any extra sets of RCAs? run a set straight from the HU to the amp, test it out, and if it works correctly then, chances are the other RCA is pinched/bad
ill check it out, thats probably it. the amps i have are both screwed to the back of my box, with one of those amps being 18 inches long and the other around 14 or so. the back of my box is around 34 inches, so its a tight fit.
check the rca's and also the rca inputs of the amp. could have a broken/loose solder in there which more than likely was caused from mounting your amps to your box. not a good idea to mount amps to your sub box.
yeah, i hate to do it, but my box takes up my entire trunk, i really need to mount it somewhere else.
one amp is for the highs, and the other is for the lows.
Two subs, same issue, two LOC's same issue, seems to me that there is an issue upstream. Have you tested the amp disconnected from the signal...
No need to bypass the amp. Most use an LOC that takes the full amped signal and turns it into a flat RCA level signal. Here is the newest I have...
308
6
452
  • Locked
NVX MVPA1 Best tiny amp Installed a bunch, but have one pushing a sealed 12 @ 2ohm in my daily beater Can bump it all day long and barely gets...
4
740
Amp
This tested well on youtube - not familiar with the brand but it is a pretty standard china build house amplifier...
5
540
wishuponansg
wishuponansg
gainesville, Fl
frostz3
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
