fuse/electircal system diagnosis
  • 1
loudlittlefvkus
Michigan
Okay, so today my subs stopped working. the first thing i did was check my fuse. a 120 amp fuse, going to a jl audio 1000/1 slash v2 amp. the fuse was kind of corroded, looked like it was burnt a little on one end (ill post pictures when my phone charges) but the fuse was not blown. then i was wondering, because i think i have a bad ground, which im about to go check out, that was the cause. can a bad ground cause that? i also had a little extra 8 gauge wire grounded from my battery to the chassis if that makes a difference in this. i went back to check my ground, and my RCAs fell loose. could that have caused the problem too? i checked my power wire and there are no breaks or melting, like i said ill post pictures of it all when my phone charges. anyone have any ideas why this might have happened?
I made a lot of money repairing fuse boxes that were destroyed from people taping into them. Pay once by doing it right. Do it wrong, the second...
14
634
It would be cheaper, it might be easier to find a place to mount it, and you would have a ton of options if you just do two, 3 slot fuse holders...
4
655
My bad, yes, I read them each as having two 4ohm coils. The JBL diagram left a bit to be desired, IMO. ;) And a double yes, thought U was talking...
9
I plan on getting the fuse to run as a front sub/midbass in my kick panels...I've heard they sound good but you definitely wont get mirror shaking...
loudlittlefvkus
loudlittlefvkus
Michigan
loudlittlefvkus
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
