Fuse per alternator recomendation or amp recomendation?
  • 2
Thatnikcufguy
CarAudio.com Newbie
Texas
SO... I have a Mechman 370a alternator and they recommend I use a 400a fuses. However DC recommends using a 300a fuses for a 3.5k amp. My question is what size should I use? It seems to me a 400a but I am not sure on this.
This is my first install so I appreciate any and all help from you guys. Obviously I spent a couple of pretty pennies on everything and I do not want to blow it all to ****. Lol
It would be cheaper, it might be easier to find a place to mount it, and you would have a ton of options if you just do two, 3 slot fuse holders...
4
609
My bad, yes, I read them each as having two 4ohm coils. The JBL diagram left a bit to be desired, IMO. ;) And a double yes, thought U was talking...
9
I plan on getting the fuse to run as a front sub/midbass in my kick panels...I've heard they sound good but you definitely wont get mirror shaking...
Sounds like a bad ground or wiring problem on the 12v+ side.
13
Thatnikcufguy
CarAudio.com Newbie
Thatnikcufguy
Texas
Thatnikcufguy
Doxquzme
    May 12, 2024
Brendon Jenness
    May 11, 2024
