Fuse size for 4 gauge
  • 5
just some off brand crap i dont remember i picked it up like 4 years ago and i just pulled it all out of storage some guy at the audio store said use a 60a fuse why would he suggest something so low if you guys are saying 120 range also if it madders im using a hooker audio fuse block
Well if my amplifier has 3 30amp fuses so would running 60a fuse do harm.And i dont know anything about electrical stuff by any means. And as far as runs its 12" of the bat fused and then about 10 feet to the amp
...some guy at the audio store said use a 60a fuse why would he suggest something so low if you guys are saying 120 range
Either the guy wasn't very smart, or he knew it was some thin budget stuff that's not really 4 awg.
depends on how many amps your amp pulls and how far of a run it is.
Not really. The PRIMARY factor is the actual cross section area of the wire. 4 ga SHOULD be good for 125A or so, but some push it to 150.
If you're ACTUALLY trying to draw 150A through anything more than 10' or so voltage drop will become an issue using 4 awg.
Not a problem. It would just give you some added protection in case your wire is not truly 4 awg. Besides, with 3x30's you'd have to be seriously blasting it for a long time to blow a 60A main.
i think that you'll be fine with 4 gauge with that length of a run. but you need to run atleast a 100amp fuse.
If it IS REAL 4 gauge wire sure, 100A is fine, but I'm not confident that it is. I think a 60A would be the best choice for now.
Bopo, if your wire is accessible just take a ruler and look at the cross section. 4 awg is between 3/16" and 1/4". 8 awg is about exactly 1/8". You'd be looking at the copper only. The insulation is not a factor.
Fuse anything going to the battery 150amp fuse I would do. if it shorts you saved your battery, and than you look for causes why it happen, if...
8
Same here. Its what my search pulls up, but its all over the place
4
958
I made a lot of money repairing fuse boxes that were destroyed from people taping into them. Pay once by doing it right. Do it wrong, the second...
14
657
It would be cheaper, it might be easier to find a place to mount it, and you would have a ton of options if you just do two, 3 slot fuse holders...
4
658
bopo668
JerryRig
bopo668
tex
n2audio
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
