G5 window cables frayed. STUCK
budahbuddy803
Aiken, SC
Well, my driver side window has made noise and functioned a little less adequately within the past 3 months. I didn't really think much of it, but yesterday, it stopped completely. I removed the door panel to check out what was going on. Turns out there are two cables that are attached to a motor and the cables are what raises and lowers the window. One of the cables is completely frayed, the other is fine. There is nothing in my door that I can see that would have caused that.
The dealership wants ~$400 to fix it. They will charge a minimum of $85 to even look at it. Ever happen to anyone? I don't want to get it replaced and have a cable do that again.... Again, I can't figure out what in the heck caused it to fray in the first place.
You can't repair it yourself? I've had the bolts fall out of the plastic clips at the bottom of the window from my stereo before. Window dropped to the bottom of the door and stayed there lol
Its a window regulator. You should be able to get this at your local parts store new. Like NAPA I am sure sells them. Its a GM car they do it all the time. Nothing cut into the cable its just going bad. Once again they do it all the time. Back in my GM days Id say I would have over 20 working motors a couple of weeks from replacing them under warranty when the regulator cables would snap.
The vibrations probably caused the wires to rub against metal somewhere...that takes time 😂
If this is your amp. it looks like there is an input for a bass remote. It looks like the input for an ethernet cable. You have to find a remote...
8
budahbuddy803
budahbuddy803
Aiken, SC
dumple
Mr FaceCaser
    May 16, 2024
Mr FaceCaser
    May 16, 2024
