GCON 18" SSA (Infinite Baffle?)
  • 6
Jake321
CarAudio.com Recruit
96
14
Hawaii
Can this thing do infinite baffle?
What is the QTS requirement for infinite baffle?
Is there any other T/S Specs that interplay?
"GCON 18" 950W Subwoofer by SSA"
"T/S Specs:
D4 / D2
Fs. 25.5 / 24.9 hz
Re 8.0 / 4.0 ohms
Qms 6.49
Qes 0.82 / 0.78
Qts 0.78 / 0.74
Cms 0.14 mm/N
Mms 304.5 / 306.5 gr
Bl 16.3 N/A
SPL 93.1 / 93.8 dB
VAS 178.0 L
SD 1210cm^2
Xmax 23mm
RMS 950 watts
SSA GCON enclosure info:
Overall Diameter 18.5"
Displacement 0.19 Cu. Ft.
Cut out 16.75"
Mounting Depth 9.5"
Sealed: 4.25-4.75ft^3
Ported: 6.5-7.5ft^3 @ 27-34hz w/15.25^2 of port per cube"
10x Vas is the minimum for a true infinite baffle setup. My current substage and my last 5(maybe 6 or 7, hard to remember) substages have been IB, and I don't believe any of them were "ideal" subs in the QTS department. My current sub(s) have a qts of .245 and a Fs of 26.5, which is very far from the ideal range of .650-.750 Qts.
I believe the Gcon would sound great in IB. Be careful with the power, and have a bit of EQ available and you should be fine.
Matt
Looks like a good candidate. Keep your power under 500 watts.
Just a heads up. I have used subs with a qts of .47 with success.
Is this 718 capable of IB?
Speaker Size (In):18
Watts RMS:600 - 1200
Watts Peak:3600
Impedance D2 / D4
VCD (In):3
Piston Diameter (In):15 1/2
Fs (Hz):26.92
Qms:6.79
Qes:0.567
Qts:0.523
Vas:170.4
Xmech (MM):80
Xmax (MM):16
Frame OD (In):18 3/8
Frame OD w/Gasket (In):18 1/2
Mounting Diameter (In):16 5/8
Mounting Depth (In):10 1/2
Motor Diameter (In):7 3/4
Motor Depth (In):3 1/2
Woofer Displacement (CuFt):0.25
Ported Enclosure (CuFt):6.0 - 8.0
Shipping Weight (Lbs):43
Price (USD):559
Watts Peak:3600
Impedance D2 / D4
VCD (In):3
Fs (Hz):26.92
Qms:6.79
Qes:0.567
Qts:0.523
Vas:170.4
Xmech (MM):80
Xmax (MM):16
Price (USD):559
What sub is this?
What kind of music do you listen to? I'm a fan of SSA's subs quite a bit. Everyone I designed for really liked their SSA's, and I do like their...
14
I picked up a couple 12's for my civic. Figured I would hook someone up on here. Not trying to nab business, just trying to turn it around for the...
4
988
Evils are made to order, but the lead time is VERY short.
13
From their website. Sealed: 0.8 – 1.1 cubes Ported: 1.75 – 2.1 cubes ported after displacement, 29-33hz tuning Sub Outside Diameter 12.500" Cut...
Jake321
Jake321
Hawaii
Jimi77
1aespinoza
    May 18, 2024
Mr FaceCaser
    May 16, 2024
