Genesis ice profile 5 audiophile car amplifier five channel new shallow mount
  • 1
TNT
St.Louis
Genesis Profile 5
NEW
Up for sale is Genesis Ice Profile Five amplifier. Handmade in England. This amp is new never played. Superior audiophile quality and sound. Very rare amp. Beautiful machined body. Perfect for low profile mounting in tight spaces.
Our Profile and Profile Ultra series balance the need for compact chassis, high efficiency and class leading sound quality.
The low mounting profile lends this series it's name, and allows installation where other amplifiers won't fit.
Vari-speed thermal management and innovative Class G technology yield excellent power outputs in small spaces with freedom from overheating, an all too common problem with other compact amplifiers.
As you would expect from Genesis the sound quality and features are second to none.
Profile Five
A fully featured all in one amplifier with every conceivable feature ensures the flexibility to run any combination that can be made with a 4+1 amp. The optional Sub Remote level control allows easy level adjustment. High level interface gives 5 channels of audio from a 4 channel Factory radio. Parametric EQ allows tuning of sub system to suit all music styles
Specification:
4 x 50W + 1 x 250W at 4 ohms/350 at 2 ohms
Smart Switching
Automatically routes the signal
Parametric EQ (P Sub / P5)
Gives full adjustment of the subwoofer sound
Thermal bias tracking
Eliminates distortion
Flexi-mount system
For easy installation
Vari-speed Thermal management
Quietly keeps everything cool
DC Sub level control
Eliminates noise pickup
Power Levels [2 Ohms]
4 x 70W + 1 x 350W
Power Levels [4 Ohms]
4 x 50W + 1 x 250W
Bridge
2 x 140W + 1 x 25W
THD
Signal to Noise Ratio
100dB 'A' Wtd
Input Sensitivity [Volts RMS]
0.3 ~ 4 Volts
Current Draw @ 4 Ohms
32 Amps
Fuse Rating
40 Amp
Crossovers HP [All Continuous] - CH 1 & 2
30 - 6000 Hz
Crossovers HP [All Continuous] - CH 3 & 4
20 - 200 Hz
Crossovers LP [/- Module] - CH 3 & 4
60 - 6000 Hz
Crossovers LP [-- Continuous] - CH 5
50 - 200 Hz
Parametric Equaliser
Yes
Dimensions H x W x D [mm]*
38 x 450 x 217
Weight [Kg]
3.0
$999
Free ship within U.S/ if you want International shipping please contact.
Is there a BT, USB or other AUX option? May be time to convert your CDs to a solid sate option and use it until you replace the init altogether.
592
I feel like its a bad set(Low tier set) of RCAs myself. I use Stinger Zero Noise and 4000-8000 series without any issues. Dayton makes a nice set...
6
TNT
TNT
St.Louis
TNT
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
