COMPLETED Genesis Series 3 Compact 4 Amplifier (4 channel amplifier)
huggy54
London
Price
$390
I have for sale a Genesis Series 3 compact 4 amplifier in very good condition and perfect working order. This amplifier has had light use and is now surplus to my requirements. This amp is best suited to power speakers (components) as its a 4 channel amp, it could also be used to run a small sub-woofer, which in either configuration will always deliver great sound and a-lot of power(especially for the components). It's a class A/B amplifier so quality of sound is very good. This amplifier is competition level amplifier and its very rare to come by.
Its very, very compact (hence the name) and as you expect from Genesis the SQ is amazing. I would just like to add this amplifier is a Series 3, which is the TOP of the Range from Genesis, even above the Profile Range, amplifiers DO NOT come better than this.
Click the link to see the image below
img840.imageshack.us/img840/556/19012012352.jpg
Specs below
Power Source [Volts]-10.8 ~ 14.4
Number of Channels-4
Rated Power at14.4v [4 Ohm]-4 x 30
Watts RMS at0.1% - Rated [2 Ohm]-4 x 60
All Channels Driven - Rated [bridge 4 Ohm]-2 x 120
Typical Power at14.4v [4 Ohm]-4 x 57
Watts RMS at0.1% - Typical [2 Ohm]-4 x 94
All Channels Driven - Typical [bridge 4 Ohm]-2 x 192
Maximum Current Draw-45 Amps
Signal to Noise Ratio 'A' Wtd [4 Ohm]->100dB
THD + Noise atRated Output-0.1%
Input Sensitivity [Volts RMS]-0.3 ~ 5
Frequency Response-20 Hz ~ 20 KHz
Dimensions H x W x D [mm]*-62 x 300 x 210
Weight [Kg]-4.2
Thermal bias tracking-Eliminates distortion
Custom capable design-Create your own unique amplifier
Compact size-Mounts almost anywhere
Bespoke terminals-Our own design optimises signal flow
Simultaneous crossovers-For complete system flexibility
I'm looking for (£250 GBR) $390 delivered.
If you have any questions please feel free to contact me reply thread on the thread.
Was Photo Included
  1. Yes
Glad you can read the rules.....
Maybe post a pic with username/date/item in question...
Also...nice first post.....overseas guy, no one knows.....maybe post some references.
Is there a BT, USB or other AUX option? May be time to convert your CDs to a solid sate option and use it until you replace the init altogether.
414
I have a pair of telza audio 12" subs for sale great condition never ran over the 1k RMS rating. I'm willing to ship just need to know a area so I...
You can stream videos off of youtube. There are some videos of Japan, and some nature videos that are awesome to watch, and show off the...
213
The 8's have a frequency response of 40hz and up. So I would cross them over at 60hz and up. And crossover my subs at 80hz. That way I would get a...
huggy54
huggy54
London
huggy54
    May 19, 2024
    May 18, 2024
