******geo Metro Wall Build ******
They are not xcons, icons, or dcons. they are special ones. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Man, one of the nicer walls I have seen.....and in a Metro, lol! Does the car move? Can it move.....//content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
Replacement subs has given an increase db?What amp now?
for now its the same power ~1200 each. The numbers have stayed the same from 24hz to 30hz, but then the numbers go down. need to triple the power for the subs to be happy.
Thanks. It moves OK, you can tell there is some weight in it for sure.
Ok then 11 cubes will be fine. Keep in mind the f/s of those woofers is about 28 hz, so you if you tune really high above that, the woofers can...
12
What would you recommend using for the roof then ? Should I do just the bpillar or the whole roof ?
917
If you order directly from taramps in brazil you can get a smart 3k for $259 shipped...
9
These are the tweeters in going to use in my truck. Beefy little guys just going by weight. Probably not the best for a car audio setup, but I'll...
63
8K
JBLCAMRY
KCB
JBLCAMRY
239, Florida
BoomTaco64
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
