Getting 2X AudioQue HDC3-A 10's or 12's. Need help
Sanchito
O.G. status
266
Houston
Which coil options should i go with to make the wiring easier?
Which way should i wire them to make the amp hookup easier?
what would my finall ohm load be and what wattage should i be running to the set?
Which size you you guys recommend in the trunk of a 09 civic for a daily driver?
what i was wondering is if eithe rof those amps would run them good and loud
what amp works good with a pair of hdc3-a's?
Why do you want the a's when the coppers are way cheaper and your only planning on 2200 rms. My 10 can take 2500 when I hook up both amps but heats up quick with just 1200watts clipped a little.
get your copper 10's. If you wanta be loud hook em to an AQ2200. If you wanta pound hook em to an AQ3500. If you wanta be sick hook a 2200to each. Make sure to get the correct wired subs for the application. Call DJ at Audioque to get it right.
Lifelong Pioneer Premier series user here. Switched to the Kenwood eXcelon Reference (XR) DDX9905S and never looked back. Excellent sounding...
9
472
Appreciate the input! I'll check out the calc site and see how it compares. I'm in the beginning stages of building the box. Unfortunately with...
4
885
Anything worth getting is always worth it more at a steep discount. Not familiar with that unit, but the brand is great.
I'm putting 2 under my rear seats with 2 passive radiators. Only a 3kw amp. Only reason I'm selling my adire subs before even trying them. Granted...
20
3K
I'm stupid. Please repeat what stupid me said that was wrong.
17
3K
Sanchito
O.G. status
Sanchito
Houston
mlstrass
Doxquzme
    Jun 1, 2024
1aespinoza
    May 31, 2024
