GIANT Welding Cable F/S (8/0)
72Impala
21FT of Black 500MCM (aka 8/0) welding cable
Used but not abused, no tears, no oxidation, just HUGE power wire. Terminals can be ordered on Ebay or you can make your own with Copper pipe. Transfers a ton of power, I believe it is 1400amps at 100' or something insane
$140 shipped for the 21ft length. That's really cheap if you look up 500MCM prices
Flat rate USPS
Picture is compared to Orange 1/0 Knuconceptz Kollosus, and 4/0 Welding cable. 4/0 is big so this kind of gives you an idea how big this stuff really is.
Thats some huge *** wire. Idk that my panels would even go back on if I ran that in my car, lol.
Definitely would want to run this under the car in most cases, or just use it from your batteries to your fuse block.
Flat rate USPS
TF you trying to power lol
Really we should all use wire this big for runs from the battery bank to fuse block, but the terminals aren't readily available as 1/0 ring terminals and there is no reason for companies to sell this wire as only few people would require it.
The larger diameter you go, the less internal resistance you get. Think of it like this::
Do you use 4 runs of 8 gauge, or 1 run of 0 gauge? Same thing, 4 runs of 0 gauge, or 1 run of 500mcm? People do like 6 runs of 1/0 when that makes no sense if bigger wire is available, the only reason it is done, is because the terminals are easy to find, fuse blocks are designed for 1/0, Ect. Just food for thought
understood. i run multiple runs of 0, but get it dirt cheap. but that is some beast @ss wire
500mcm is $13 a foot used on ebay and $18 a foot new. That's plus shipping, I'm selling for less than $7 a foot shipped. I have no idea why this is still here
No make or model number on it? Do you have an exact picture of the rear and all its glory?
8
857
https://www.ebay.com/itm/263364485734?mkcid=1&mkrid=711-53200-19255-0&siteid=0&customid=link&campid=5335951755&toolid=20001&mkevt=1
Hi, if no one here is able to help you figure it out, try over at diyaudio in the car audio section, it is a more technical forum. This is one of...
Oem cables are readily available for most vehicles. Check rockauto. Anything less will be a future headache.
10
72Impala
72Impala
Clarksville, TN
72Impala
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
