Good 300 Watt RMS 12" Subwoofer?
  • 5
This Is a NIB amplifier, one of two that I was to use. Decided to go class A/B on the front mids and tweets and just purchased a Helix B FOUR...
Good thing its under warranty and that you have contacted A.Control about the issue so it has been documented. It will help speed up the return...
6
He wants to strap the amps to double the output to one sub. Some amps allow you to "couple" them. This allows you to wire up the one sub powered...
5
You can wire those subs up @8 ohms if they are both SVC4 ohm subs,and that amp will run fine after being tuned properly...
4
Nutz
Team Nutz, Pgh PA
Nutz
Pittsburgh, PA
Nutz
1aespinoza
    May 18, 2024
Mr FaceCaser
    May 16, 2024
