Good 3k Amp
http://www.amazon.com/FSD-Audio-5000-Watt-Monoblock-Amplifier/dp/B00WZVD1BW/ref=sr_1_1?s=car&ie=UTF8&qid=1442288890&sr=1-1&keywords=fsd+5000
right at 700
I'm selling two Taramp's DSP3k 1 ohm versions. They've been installed for less than a month and are in pristine condition. These are the newest Taramps and are much more sturdy. They have an onboard voltmeter, clip indicator, flat response down to 8hz, a clipping limiter (set it to 1% or 10% THD depending on your tastes, turns the amp down instead of clipping!), lots of crossover options, and tons more features and improvements. They're also a lot smaller than a Korean 3k.
I'm asking $450 shipped each. They still have over 10 months left on the warranty. I'm only selling them to upgrade to a larger amp, probably a HD10k
Pmd
Subs play to the beat with gain low but if I turn it up my subs play loud unwanted never ending bass that is constant and wont stop until I turn...
You have a blown cap in the amp more than likely. Had the same thing happen to a soundstream amp.
226
430
Fi-brations
Fi-brations
Memphis, TN
rfluvinmf
Decebal
    Jun 10, 2024
Decebal
    Jun 10, 2024
