Good choice?
  • 2
cbuts
Hey guys 2019 ram classic 1500 crew cab.
Recently ordered JBL stadium gto 960 components.. my installer said they didn't fit well and instead insisted I order some Kenwood Exelon Dr 1800 and said he has some tweeters for me.
Looking at the specs the JBL seem louder? Better specs?
Was my first choice a better louder option? I told him I want loud and this set is pretty much the same RMS as my last one .
I want LOUD. Did I make a decent choice with the kenwoods ?
Thanks
Thanks
is your truck factory? new aftermarket
Speakers alone will
Not likely make your sound louder
did you mean xr or dr?
Sorry, your other post was more of what is needed to give input. Those knewoods are coaxials if I looked correctly so there’s a tweeter already built in. The gto960c is a Comp set with a passive crossove and separate tweeter driver. The jbls run 2 ohms the Kenwood run 4 ohm. The sensitivity on the jbls is 94 and 86 for the Kenwood coaxials. The jbl’s will have better imaging as it will bring the tweeter up higher toward your face.
maybe I looked up the wrong thing or your installer has some strange plan but the two things i looked at are not apples to apples
Thanks for the reply bud 🙂
Yes you are correct, but we are also going to add a tweeter alongside the coaxial, that is what he said anyways . Would this make it better in that sense ? It's a bit confusing to myself so I'm just wondering if he made me downgrade a bit instead from what I originally picked .
I've already ordered the kenwoods and plan to return the jbl, I guess I'm looking for a bit of relief on the situation lol
If it were me on the options you picked I’d put in the jbl Comp set it has crossovers that are actually designed for the drivers. The coaxials and separate tweeter thing on two channels sounds bootleg and less than ideal for imaging and distribution of power.
LOL. Ya man. Its been busy. Im off today, but got stuff to do around the Casa.Be a Great sub man, and very nice amplifier. If you can swing a few...
18
Tex, if you have Sirius/XM, were you able to use your OEM antenna or did you have to install the one that comes with the kit? Good job on the...
28
4K
Probably...really depends on the length of the run though...the longer a wire gets the lower the carry capacity gets (at least from how I...
True. I do need to study up on the lithium. And as for a disconnect between the winch, system and batteries... there is truth. Any battery or...
6
cbuts
cbuts
canada,ont
BCotrell
1aespinoza
    May 18, 2024
Mr FaceCaser
    May 16, 2024
