Good deal? Ok system?
  • 3
noleafclover803
ok first car, first system, I'm 16. I've got a 1995 Eclipse GST that had stock premium audio. I now have:
-Aiwa CDC-Z137 head unit - with Aux input and 1 set of pre-outs
-Two 3-way Rockford Fosgate 6X9 rear speakers powered by:
-"Dual" 340 watt max (60wX2 RMS @ 4ohms).
-15" Single Voice Coil Rockford Fosgate sub powered by:
-"Concept" CC-452 - 150Watts x1 RMS @ 4ohms
I just bought the Sub/Box and Concept amp (already mounted to box) used from a friend for $170. Is that a good deal? The amp seems pretty decent, I'm yet to find another amp for under $250 that puts out more then 150 watts RMS (looking at 800watt and 700 watt "max" amps all do 150 RMS). This amp alone is selling for $125 online. The sub and box are also in very great shape and sound good. Did I get ripped?
Also, how is the overall system so far. I'm going to be replacing the stock front door speakers also probably with Rockfords, for an all-around rockford system. Anything you guys can reccomend to add? I need somthing to make money for :p
Um, yeah you probably lost quite a few bucks, there are quite a few amps that put out well over 150 watts for under 250. There are even quite a few in the 600 rms range (max doesn't mean anything).
Im well aware that you paid a whole lot of money for something that is worth about 50,
edit: sorry, didn't see you got the sub too, maybe all that is worth about 90
(NEW) Pioneer 9" DMH-T450EX Digital Multimedia Receiver with Weblink - $189.99 - Free shipping for Prime members...
The one you linked is still a bit iffy if you intend to push things. Consider the cells are rated 100A Max discharge which means if they're the...
5
It looks like you have the wrong connections. The head unit uses one amplifier to amplify 2 to 4 of your speakers. You are using 2 amplifiers...
5
160AH lithium that supports a 12K system is pretty lofty! I've seen dual 24's or quad 12's that will do this. Most of what 've run across is dual...
341
noleafclover803
noleafclover803
Kansas City
Bavarian3
Decebal
    Jun 10, 2024
Decebal
    Jun 10, 2024
