Good not so expensive amp
That 12W7 is a retarded single voice coil 3ohm which forces you to spend more than you want on the amp. Why do you want an expensive sub and cheap amp?
What impedance will you be wiring to? I think kyou can wire to 1.5 ohms at the lowest with the W7.
And why are you going with the W7? Have you got it yet?
If not, I'd suggest you look into some other options unless you are getting a GREAT deal on one.
Consider the depth of discharge chart for LTO: Charging up 16V or above may not hurt them but it certainly isn't gaining you much of anything...
77
8K
Subs play to the beat with gain low but if I turn it up my subs play loud unwanted never ending bass that is constant and wont stop until I turn...
You have a blown cap in the amp more than likely. Had the same thing happen to a soundstream amp.
244
Arkel23
Arkel23
Florence,SC
Jh8909
Decebal
    Jun 10, 2024
