GPcarAudio.com Pro Seller
Supporting Vendor
GP NO SAG SPRINGS - gp car audio
Ground Pounders, an easy and permanent solution to end horrible sag, return your car to stock ride height/ make it drivable again and recoup handling.
We have teamed up with a local OEM, DOT approved spring manufacturer to do custom one off sets of springs.
These are Springs manufactured at your OEM SPECS BUT, for the added weight you have added in your vehicle.
500-2000 lbs of addition weight. 2,000 lbs + please inquire for a quote.
Example: if you added 2) 100lb subs a 100lb box, 2) 100lb batteries, and a 50lb amp, you would need to order 550lb springs to return your car to stock height.
This is a precision made product and can take up to 4 weeks to be manufacturerd.
*DIRECT SWAP COIL SPRINGS ONLY, LEAF SPRINGS CURRENTLY NOT AVAILABLE*
