Ground: 2 4ga vs 1 0ga
  • 4
neo_styles
AKA Pop Twidget
3,722
WA
Still coming up with plans for my install. I'll be running 2 four-channel amps, neither of which can accomodate 0ga wire, so I'm forced to use 4.
Option 1:
Run each 4ga ground to a distro block to a single 0ga wire, then run the 0ga to batt negative.
Option 2:
Run each 4ga ground directly to batt negative.
What would you recommend? Am I going to be limiting myself in current going one route or the other? I just realized it's cheaper to get the extra 4ga I'd need to cover the extra distance from Knu than it is a ground distro at this point.
How long would the runs of 4ga straight to the battery be? Probably just go that route if they aren't long, less connections. Less chances for things to go wrong, less possible voltage loss as well.
Somewhere between 3 and 5 feet each, depending on how I conceal the wiring.
And apparently Knu does have the reducers...at 3.50 each.
3-5 feet is easy, don't do a distro. 4ga or 1/0ga w/reducers is up to you, depends on what you think you will be doing in the future. And fusing ground is a good idea, but also up to you. 3-5 feet, as long as it's ran where it won't be tampered with, you might not need fuses, but they are there to protect shorts in the wire. Honestly, I probably wouldn't if it was my install.
Hmm...gives me something to think about. So how about this on the no fuse concept?
2 Knu battery terminals
1/0 gage from terminal to each amp with reducer (power)
1/0 gage with reducer from each amp to battery terminal (ground)
Single ground. If there is one thing car audio proves it's that the saying "Ground is ground the world round" is complete BS.
4
454
I'm guessing that's what it is. There's not a lot of room back there.
12
It’s nice having a test bench. That one is nice and clean! I don’t have pics of mine but mine is built all out of wood with carpet top and all...
16
In the following order: DOWN4SOUND JFX653S - 6.5 INCH 3 WAY CAR AUDIO SPEAKERS - I did a good listening of these and was pretty impressed. It...
20
3K
Yeah I saw a lot of that when doing those installs as we also did surround sound system wiring as well. I always ended up being the doing it as...
11
neo_styles
AKA Pop Twidget
neo_styles
WA
jteske88
Decebal
    Jun 10, 2024
