Grounding question with 2nd Isolated battery.
  • 2
crownroyal
BILLY MAYS HERE FOR COKE!
So I have been running my system off stock electrical, pushing a Massive Audio 5 channel (800rms sub+120x4).
Wolfram was selling those C-2400.1 so cheap I said what the hell, My Dark A.I. DKI-15 can take it!
So now Im about finished runing the 1 guage to IB500 isolator relay to a Shuriken 120ah battery.
This is the first time ive dealt with a 2nd battery set up and I'm not sure of the grounding.
I have the c-2400 grounded to the battery which is grounded to the chasis.
Is it imperitive to ground my Massive Audio EX5 (running only the cab speakers) to the battery like I did the sub amp (6ft run)or can I just ground it to a closer spot(2 ft run)
Thanks!
I don't think anybody uses battery isolators any more so I can't help you there, but as far as grounding amps it shouldn't matter so long as both batteries are well grounded to the frame and everything else in the audio signal chain is also properly grounded to frame or battery - terminal.  IF you wind up with engine whine that'll be the first thing you want to experiment but if everything is grounded solid it should not be an issue.
Yes Frame is best if second battery is in the rear.There are plenty of bolts and even unused holes in the Frame that can be used for an excellent...
7
Oh ffs...he's jumped a car twice and is now an expert on car electrical systems 🤣🤣🤣
4
977
I had a really hard time with my 1990 240sx. That had to have been the hardest car to wire up and install to date. The doors were something else
7
crownroyal
crownroyal
On the river,TN
hispls
Decebal
    Jun 10, 2024
