grounding question
ill_ace
I am ready to start my install but I was confused about picking the right grounding point. The manual for my ppi amps says that if the system has over 300 watts then you should ground to the battery. This doesnt seem right to me because i dont think it is that common for people to ground to the battery. Does anyone have any suggestions for finding a good spot. I know I have to make sure there is no paint and stuff like that.
I agree with Frost, you should use a DMM if you have one. If you dont have one, you should go buy one, $10 or something at radio shack. You will want one if you are into car audio. Anyways, you dont NEED to use one to find a good grounding spot. Make sure your ground is well sanded, it should be clean of dirt, grease, paint, basically you want a strong metal-->metal contact. Use a bolt to secure your ground if you have to drill your own hole, and use a ring terminal or something similar to contact the bolt.
If you dont want to get/use a DMM, dont worry about it, just sand, keep the wire pretty short, and make a strong connection. If you have alt whine/ or induced noise after you get everything set up, then you might want to find a better grounding spot.
By the way, ive never understood the whole "grounding to the battery" deal. I mean running a ground all the way back to the - terminal and then your battery itself gets grounded to the car chassis...
Im no expert though...so maybe i'm missing something.
You are, it's called resistance on the ground return and it equates to you eating a foot long sub and having your butt cheeks sewn 90% shut..... A good ground is under 1/2 ohm of resistance. A seatbelt bolt is generally not a good ground point as typically they are spot welded on which adds resistance, so not a good idea overall. Precision is correct, follow their advice.
Uhmm...
Just about every piece in a honda car is spot welded.
So what am i going to do now ? //content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gif
Take one probe and attach it to the neg terminal on the battery, take the other and touch it to the spot where you intend to ground. Set meter to read ohms resistance and off you go. Test it in multiple spots, you'll see how crappy a ground return most cars really have.
you will need a piece of wire to run back to the battery that hooks on the DMM's probe
I used jumper cables //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Old thread but I want to try this - Do you have to disconnect the terminal that goes to the negative post on the battery? And then you hook up your DMM lead to the - battery post, or the the terminal?
Also, how do you check the resistance of your extension wire? Supposed to subtract that resistance from the total number.
Yeah, WAY under a half ohm. At a half ohm you would get a half volt drop across your ground for every amp flowing through the ground path. If you can measure the resistance of the ground that you choose directly with a basic DMM, it's not a good ground.
The nut that the the seatbelt bolt threads into is usually held in place by some pretty good welds and is on the most substantial piece of metal in the car (not that that is saying much in many cases)
I ground back to my battery but I also wired a small system with 1/0. Total overkill in my case. 300W should be completely fine with a normal chassis ground.
Actually that is totally backwards, the chassis is grounded to the battery. The ground plane in a car is the negative battery terminal, not the chassis.
one quick question...While measuring for resistance I was playing with my battery and ground...I got different readings depending on if I used the pos or neg probe....I tried this with another meter the same thing...So question...Which probe do you use on the battery side? //content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
Yes Frame is best if second battery is in the rear.There are plenty of bolts and even unused holes in the Frame that can be used for an excellent...
7
Oh ffs...he's jumped a car twice and is now an expert on car electrical systems 🤣🤣🤣
4
975
I had a really hard time with my 1990 240sx. That had to have been the hardest car to wire up and install to date. The doors were something else
7
ill_ace
ill_ace
Westchester, New York
Louisiana_CRX
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
