**GROUNDING the amplifiers! More POWER?**
Only if your current grounding point at the chassis is poor. The only time it might be worthwhile is if you're into spl comps and you wanted to squeeze out a few more tenths
In reference to that question... in adding a second battery to the back. Would one need to run a + and - from front to back? Or, could you ground the second battery to the chasis in the back, assuming all of the car's stock grounds have been upgraded to an equivalent cable to that of the + run to the back?
Yes Frame is best if second battery is in the rear.There are plenty of bolts and even unused holes in the Frame that can be used for an excellent...
7
Oh ffs...he's jumped a car twice and is now an expert on car electrical systems 🤣🤣🤣
4
946
I had a really hard time with my 1990 240sx. That had to have been the hardest car to wire up and install to date. The doors were something else
7
swollen_cu
swollen_cu
New Orleans
LosIsATool
audiobaun
    May 19, 2024
1aespinoza
    May 19, 2024
