H.O alternator?!?
Need help ! I have a 2000 toyota avalon with stock alternator! Im running two 12 inch jbl s3's which are 500watt rms each! I am powering them with a audiopipe 15001d it is rated to do just under 1000 watt rms @2ohms which is what i have it all set too! The s3 have the ohm selector switch and all! Anyway my headlights are dimming crazy like ive seen befor very very noticeable! I can really see that my amp proly starves for power quit often when im playing music loudly! Im having finding a HO alternaor am i trying to upgrade the wrong component or what! And befor yall ask i have a deep chcle bosch premeium agm battery the GD thing cost me almost 300 bucks
The big 3 meaning deep cycle battery HO alternator and higher gauge wire from the alt to the battery! This i am ok with upgrading all i need is a place i can get a HO alt! I have googled this and no luck so far
DC Power, Ohio Generator, Singer, Mechman...all make HO alt's. Several other companies around as well, but those are the ones that I can think of right now.
Hello I also have a question I want to buy 160ah lto, i.e. 4 banks but I have a stock alternator of 140 a and a maximum load of 14.9 do you think...
Okay cool bc I'm thinking about getting 5k amp and just wasn't sure if that battery would do but I appreciate all the help
18
I don't have one...but I check my voltage with a dmm once a week or so
12
You just found your own solution. Move the DSP elsewhere. The RCA is triple protected but not the RCA plugs. I do not know if there is a mesh or...
TwoFosgate12's
TwoFosgate12's
Lake county , CA
Austin175
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
