harness problems
  • 2
kirstin
ms
Thanks for the help, alll i need to know now, is how do i hook up my rear 6x9 wires to the back of the head unit(cd player) .
I got it installed at circuit city and there are
2 harnesses connect together, 1 going to the head unit and the other end of the 2 is going to the factory wiring of the car. This car origanaly only came with to front speakers, no wiring to the back. So i dont see were i can hook the rear ones up.. unless i splice some wires, but which ones?
Us use the harness coming from the cd player. If it's a 4 channel cd player you can use the rear channels. Check the wiring diagram that came with the cd player and see if it has rear channels and use these wires.
Based off GM pickups of the same year (and that was GM), It SHOULD just be for the vehicle sounds that play through your stereo, such as the door...
While most Asian and African markets will identify Honda's small hatchback as the Jazz model, most Western regions will know the same model as the...
116
Your image doesn't really show anything. That could be 3 different head units for all we know, but I think it's 2 different add-ons. It sounds...
978
I would make a call, or send like Crutchfield or Sonic Electronix an Email or even Chat with them and see if they can help you get the correct...
12
kirstin
kirstin
ms
kirstin
1aespinoza
    May 18, 2024
Mr FaceCaser
    May 16, 2024
