Has anybody tried the DD sigal processor?
  • 3
Shroomic
I saw that they have one listed on their site that sounds good to my noobish ears. Has anybody tried them out or heard anything about them? For 269 it seems almost to cheap to be made by DD.
Also, would i still need an active head unit to run active with one of these or does it filter by itself if you get the 1.1
works just like it should. its a great crossover for active installs but it doesnt have the flexiblity of other dsps which combine time alignment, crossover points, and eq.
combine this with a good deck like the alpine cda117, cdehd149bt, and other decks that offer decent eqs and built in time alignment. an smd cc1 works great is setting the cossovers precisely since the ddx1 is an analog unit
Alright. I do have a local deal on an eclipse 7inch. Has time alignment and im sure more on it. Might just get it first then worry about the processor if i cant customize it enough. Thank you.
If you buy a replacement OEM Radio Harness the colors will match up then you can use a wiring harness to connect to that. According to a few...
I use these and they work great. I splice them right before the LOC. One leg on the negative the other on the positive.
My 1964 fender vibroverb. It’s a tube amp for guitar. It has broken many times. But it is a serviceable amp. I can fix it.
73
13K
Shroomic
Shroomic
Fort Pierce, Fl
calebkhill
Dylan27
    May 18, 2024
Dylan27
    May 18, 2024
