Ok so I had a Kenwood KAC-7201 amplifier and a Infinity Reference 860W 1000W 8" Single 4 Ohm Subwoofer. All worked well had the sub Bridged (I dunno if this is what messed ti up or..). But like I said it worked great until my car got flooded and the amp was submerged in water. Power ran through the amp until the battery died. This is where maybe the power went to the sub and fried it? Anyways replaced the amp with a Kenwood KAC-6104D. Worked for about a week then stared randomly not working. I discovered that if you had it turned up and pressed the sub it would work until you tuned it down. Anyways Now I'm putting a JL AUDIO® 8W3v3-4 8" 4-OHM Sub in. Now when I go to wire this thing to the amp is it bad to wire it 2 ohm? Sounds obvious to me but the other sub was fine, I think lol. I guess I dont know the effect of running a 4ohm sub with 2ohms? Also how do I wire this sub two ohms? just use one channel *dont bridge*?
Thanks in advance
Thanks in advance
