Having a problem with Ignition wire
  • 3
sacarap
Hey everyone,
I am new here but could really use someone's help. I have a 1994 MItsubishi Galant. I am installing a Sony xplod cd player and have come across a problem. I had everything working but when I was mounting the player I had a loose wire (ignition wire) and it got grounded out with the car on. Now my cd player will not turn on with the car because that wire does not have any power coming from it. I know the radio is not blown because if i hook up the ignition wire strait to the constant 12+v then it will turn on.
So my question here is: Would there be another fuse other then in the main fuse box, for that ignition wire? I put the volt meter on it and its definitly dead. I checked in the cars fuse box for a fuse, but it doesn't have one there. I am guessing that there is another fuse somewhere, but I'm not sure where!!
Any feedback would be greatly appreciated !!!
Thank you !
try to trace it from teh fuse box to the deck. I cant see why there would be another but its very possible...If you are using a harness adapter you may have meltd it around the connection try disconnecting it from there and test for power again.
Mike
I had the same exact problem. You will probably need to simply replace your "RADIO" fuse in yourfuse box, and all should be repaired.
edit...I just read your post agian, and I don't know if you replaced the fuse, so I'm leaving it here.
[ 12-14-2001: Message edited by: IowaBoomer ]
https://www.caraudio.com/threads/all-bnib-focal-fdp-4-600-ds18-exl-p2500-1-sundown-audio-sfb-1000-4d-350x4-4ohms.614462/ :)
18
802
Seems kind of stupid to prevent helping others with advice on equipment from Amazon, doubt that Amazon is preventing this either. Pain in the arse!
14
813
I would Double check the LC2I settings also and make sure all wiring is secure and not loose as well.
Update I have been playing with the silver flutes and just can not get what I want out of them. I spoke to stereo integrity today and ordered a...
9
I'm not a big fan of Brand X personally. My car idles at 500rpm and my Autotech didn't turn on until 650. I sent it back and he redid it to turn...
4
835
sacarap
sacarap
IowaBoomer
GoldCountryCA
    May 5, 2024
GoldCountryCA
    May 5, 2024
Latest topics
