Head unit cutting in and out
  • 3
GreatTyler
CarAudio.com Newbie
Hello all,
I have been having an issue with my head unit lately and need some help. Whenever a song with decent bass is playing and I turn the volume past 20 every time the bass hits the music cuts out and the head unit goes black for a split second then comes back and keeps playing but the issue keeps happening at every bass hit. I took the head unit off and hooked the speakers up individually and tested them at high volume one at a time and they were all good, it only happens when they are all hooked up. I redid all the connections including the ground and tested the power and it all seemed fine. I am at a loss here and was wondering if anyone had any suggestions, below are my specs
I installed these in my 2011 Honda Accord,
Head Unit = Alpine iLX-W650
Speakers = 4 Kicker 43DSC6504
No sub or amp
I am thinking the head unit itself is shorting when getting a certain amount of power but I'm not sure how to test that. Thanks in advance for any advice
One or two, they are still subwoofer outs and are mono summed signals from both left and right. Even the 2 RCA subwoofer pre-outs on the 2nd one...
468
There are a couple of options. You can use a marine bt unit. They come in the size of a hockey puck and can mount anywhere. This is the marine unit.
581
There are bluetooth amplifiers. You can just use your phone or an I Pod as the music source and not touch the radio.
Avoid jvc 480bhs hard to see the display in the daytime even with the brightness all the way up also not as easy getting to the audio menu like...
5
715
I have a 06 grand Marquis. Looking at either Kenwood or Sony Apple play. Is it worth have a floating monitor? Pros and cons?
GreatTyler
CarAudio.com Newbie
GreatTyler
Maryland
audiobaun
Doxquzme
    May 12, 2024
Brendon Jenness
    May 11, 2024
