Head unit distortion
  • 4
Thanks. Did the 1k test tone at 0DB 23 to 24 is a small change in pitch. Once at 25 it's a very noticeable change on internal head unit amp. On loud recordings I find 24 to be around max. While lower ones 26 to 27 is max before I hear a little distortion in mids and highs. Ordered the Alpine S series 12 inch sub to match my s series 6.5 coxials. Used a 50hz 0 db for setting my sub amp gains. Gain landed right between a quarter and a the nom setting. 34.7 volts which is very close to the 34.64 target.
Alpine says the Maximum Pre-Out voltage is 4v. You can test this in a primitive way with a VERY cheap harbor freight red multimeter. Set EVERYTHING flat in the head unit, EQ's, bass boost, loudness off. Send that 1Khz 0db tone through the head unit and with a multimeter test the RCA out's of the head unit turning up the volume until the meter reads 4V. Look at the volume level your head unit is at. That's your max undistorted volume. To be safe, back it off one click. Do the same for your Sub out as well but use a 40hz tone. If the volume is lower than the other RCA's then use the lower volume number. If it is higher, use the lower volume number.
I don't think so, it is the standard radio/speaker combo that comes from factory, but I will do some research to make sure there isn't one hidden...
925
6
116
One or two, they are still subwoofer outs and are mono summed signals from both left and right. Even the 2 RCA subwoofer pre-outs on the 2nd one...
530
There are a couple of options. You can use a marine bt unit. They come in the size of a hockey puck and can mount anywhere. This is the marine unit.
630
There are bluetooth amplifiers. You can just use your phone or an I Pod as the music source and not touch the radio.
/////lpine 85
CarAudio.com Newbie
/////lpine 85
Lake Jackson
audiobaun
Mr FaceCaser
    May 16, 2024
Mr FaceCaser
    May 16, 2024
