Head unit goes in protection
  • 2
I recently added a 10 inch sub with a 300 watt built in amp. My head unit is a pioneer super tuner 3d. After I installed the sub the stereo was great for about three days. Then all of sudden the head unit started shutting off at high volumes . I don't know where to start to solve this problem . I need some help cause I'm not that great with this stuff lol
Usually if a headunit goes into protect it means a speaker wire is touching ground...since it seems to have happened after adding the sub you might want to check your speaker connections especially in the door because they have a tendacy to touch metal around the speaker connections where it’s close to the opening ..another is to check your grounds ..the amp may not have a proper ground so when it starts drawing current ..it’s pulling the ground through the rca cables to get the needed ground to produce power so the deck protects itself
I have read about this, and honestly the installer did nothing wrong. It's the newer vehicles that have the automatic engine stop/start (instead...
995
6
154
One or two, they are still subwoofer outs and are mono summed signals from both left and right. Even the 2 RCA subwoofer pre-outs on the 2nd one...
553
There are a couple of options. You can use a marine bt unit. They come in the size of a hockey puck and can mount anywhere. This is the marine unit.
657
There are bluetooth amplifiers. You can just use your phone or an I Pod as the music source and not touch the radio.
Kentuckyrose
Kentuckyrose
West port island maine
Louisiana_CRX
audiobaun
    May 19, 2024
1aespinoza
    May 19, 2024
