Head Unit Going into PROTECT eeek
  • 2
macq32
For the last few weeks my head unit has been going into protect at lower volumes after 20 minutes of play, sometimes more sometimes less. My initial thought was that my battery has crapped out on me, and it was time for a deep cell battery (yellow top/powermaster/kinetik). However I checked the running voltage and I still over 14v. My system is outlined in my signature.
I have owned the Kenwood eXcelon kdc 791x for 2 years now and it hasnt given me any problems of any sort until recently. I had set it up so 25 was my max volume and safe for all amps. Since the HU has been going into protect I let 21 be my max, and now I'm down to 18.
The unit seems to be less capable of the power it can handle. I'm doubtful that there is something wrong with the ground, since it had never gone into protect for most of 2 years and nothing has changed as far as the head unit is concerned.
I'm thinking it may just be my headunit. But if there are some other ways to diagnose the problem I would like to do that before I go buy a new unit and find myself with the same issue.
Any advice/suggestions would be very appreciated. Thanks guys
If You have the HU grounded to the factory harness Ground . I would first reground your HU ground to something else. Try that.
6
361
One or two, they are still subwoofer outs and are mono summed signals from both left and right. Even the 2 RCA subwoofer pre-outs on the 2nd one...
676
There are a couple of options. You can use a marine bt unit. They come in the size of a hockey puck and can mount anywhere. This is the marine unit.
747
There are bluetooth amplifiers. You can just use your phone or an I Pod as the music source and not touch the radio.
Avoid jvc 480bhs hard to see the display in the daytime even with the brightness all the way up also not as easy getting to the audio menu like...
5
916
macq32
macq32
Charleston, SC
macq32
Doxquzme
    Jun 1, 2024
1aespinoza
    May 31, 2024
