shakenbass
Hi all,
I recently installed a JVC KD-X50BT HU in my car as well as a little Dual 8" Subwoofer enclosure, and a pretty boomy pair of 6x9's in the rear as well.
While the 6x9's can do 100w RMS, I want to keep the bass signals away from them currently as they are only being powered by the head unit, so bass gives them a decent amount of distortion at anything higher than 20 watts going into them. My head unit has a high pass filter setting, which from my knowledge should ONLY cut the lower frequency signals to my rear and front speakers, the subwoofer should be unaffected! However switching the HPF to on absolutely, %100 diminishes the bass in my vehicle, even from the sub. If I watch the subwoofer, I can see it vibrating, and there is a small amount of air displacement coming from the port, so I know its still working. However if I switch the HPF to off again with my hand in front of the port its almost like my hand is suddenly getting ****** into a vacuum, the HPF is cutting all bass to the subwoofer as well while on.
Does anyone have any ideas as to what could be causing this? Is it something wrong with my HU possibly? All my wiring seems correct, so any help would be appreciated!
