Head Unit Install Question
  • 4
I am installing a headunit for my buddy with a 2001 Dodge Durango. I was wondering how to get the dash apart? It looks as if I have to remove the whole dash piece inorder to access the headunit. Thanks
hahah ur gonna love this one
ok u need to remove the whole trim piece, under neath and u need to remove the piece that surrounds the gauges, i wish i still have my dad install guide but if go to cruthfield u can prolly find one, u have alot of annoying work ahead of u good luck
Huh? The Durango is a 30-second disassembly. The whole panel just pulls off. No screws, no unplugging. Just turn the key on, shift into low gear (just to get the shifter out of the way) then carefully pry around the outside edge of the panel. I've never needed more than my fingers to do it. Sometimes a few of the metal pressure clips will come apart from the panel; then you'll have to re-attach them before the panel can be put back on. But there's nothing complicated, time-consuming or difficult about it.
Pull the head unit out, and at the harness use a test light to check 12v, ground, and Accessory. If all three are good, you have probably...
7
Youll need a Honda Civic reverse radio wiring harness and 20 toyota radio wiring harness ...match colors of wires and shes ready to go...
Installing a Jensen CAR710W head unit in my sons 2013 Volkswagen Golf. No steering wheel controls. I purchased the XSVI-9003-NAV wiring harness...
6
490
One or two, they are still subwoofer outs and are mono summed signals from both left and right. Even the 2 RCA subwoofer pre-outs on the 2nd one...
760
concept11253
concept11253
Moorpark, CA
KaeZoo
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
