Head unit is shutting off
  • 3
mibz.1013
CarAudio.com Newbie
Well I’m lost, my hu has been shutting off once the bass hits but turn right back on, however if the truck isn’t moving and Is in park it won’t shut off even if I turn the music up (same song) not sure if its a lack of power from the alternator or a bad ground what do y’all think ?
Your alternator produces more power/amps at higher RPM's. Nevertheless, it does sound like a power issue.
1) Have you upgraded the big 3?
2) Clean tight connections at the battery?
3) If you're using the factory ground for your HU, it's probably time to upgrade that.
4) Is you're amp grounded to a shiny on the car free of paint? It's possible you choose a bad ground location.
6
173
One or two, they are still subwoofer outs and are mono summed signals from both left and right. Even the 2 RCA subwoofer pre-outs on the 2nd one...
565
There are a couple of options. You can use a marine bt unit. They come in the size of a hockey puck and can mount anywhere. This is the marine unit.
669
There are bluetooth amplifiers. You can just use your phone or an I Pod as the music source and not touch the radio.
Avoid jvc 480bhs hard to see the display in the daytime even with the brightness all the way up also not as easy getting to the audio menu like...
5
818
mibz.1013
CarAudio.com Newbie
mibz.1013
Waco texas
Jimi77
Mr FaceCaser
    May 20, 2024
Mr FaceCaser
    May 20, 2024
