Head unit or iPad Mini + Sound Processor for system
  • 1
DanClark
CarAudio.com Newbie
So I am planning to build a system in my Ford Excursion and can’t decide on whether I want to use an iPad mini with a sound processor behind it or a nice double din head unit. What do you guys consider the pro’s and con’s of each? I mostly listen to the radio and CD’s but I hear that there are now digital downloads that rival or beat CD’s in terms of SQ and I think that an IPad mini would give me a great source for both.
The other parts of the system will be a 3 way component speaker setup in the front doors and two nice 18” subs in the back. The front pair of 3 way components will be powered by separate 2 or 3 channel amplifiers and the subs will have a mono amp on each one for a total of 2 amps and 2 subs.
Any pro’s and con’s or advice or suggestions would be great.
It is usually reserved for completely customer installs, but here is some info on using the iPad as the HU...
One or two, they are still subwoofer outs and are mono summed signals from both left and right. Even the 2 RCA subwoofer pre-outs on the 2nd one...
387
There are a couple of options. You can use a marine bt unit. They come in the size of a hockey puck and can mount anywhere. This is the marine unit.
553
There are bluetooth amplifiers. You can just use your phone or an I Pod as the music source and not touch the radio.
Avoid jvc 480bhs hard to see the display in the daytime even with the brightness all the way up also not as easy getting to the audio menu like...
5
672
DanClark
CarAudio.com Newbie
DanClark
Arkansas
DanClark
Brendon Jenness
    May 8, 2024
Doxquzme
    May 8, 2024
