head unit under 100$?
On a serious not, please tell us some more info.. New, or is used ok? Does it need to play cd's, ipod controls and pandora, or is cd/mp3 fine?
Do you plan on running a system off this, or is it a simple hu replacement? help us out here friend:)
haha. well i want it to be new. i want it to play cd's and have an aux. you can get one with pandora!? if its close to 100$ for pandora id be willing to pay some more.
I expect most sub-$100 head unit to be pretty bad by car audio enthusiast standards, so I rarely bother to research them. Expect so-so build quality and components. Usually just one pre-amp out. Weak DSP. Often no USB, or only front panel connector. Forget about bluetooth phone support, HD radio, etc. It's a great head unit to buy if you use it primarily for listening AM radio talk shows or if you need to replace your expensive HU before selling the car. Having said that, I'd probably go for some kind of JVC product just because I had one before and it had worked for almost five years before it started skipping CD music.
6
363
One or two, they are still subwoofer outs and are mono summed signals from both left and right. Even the 2 RCA subwoofer pre-outs on the 2nd one...
677
There are a couple of options. You can use a marine bt unit. They come in the size of a hockey puck and can mount anywhere. This is the marine unit.
748
There are bluetooth amplifiers. You can just use your phone or an I Pod as the music source and not touch the radio.
Avoid jvc 480bhs hard to see the display in the daytime even with the brightness all the way up also not as easy getting to the audio menu like...
5
917
Seehafer27
Seehafer27
Corona, SD
zako
Doxquzme
    Jun 1, 2024
1aespinoza
    May 31, 2024
