Helix P-DSP - Great Processor at a **** FINE Price
  • 1
ricebowl
Helix P-DSP Digital Signal Processor
As new other than a line in the screening of the word Germany (see pics). Was mounted in a glovebox its whole active life. Updated to latest firmware.
$350 Shipped CONUS
Included. Specs Below.
---------- Post added at 05:42 PM ---------- Previous post was at 05:42 PM ----------
Helix P-DSP Specs:
**Almost exactly the same as the current model Helix DSP from what I've gathered. Verify the differences if it has any bearing on your purchase decision.**
  • DSP settings and adjustmenets made via laptop or PC through USB port
  • download DSP PC-Tool Software from helixhifi.com
  • 6 assignable inputs
  • inputs: 6 RCA preamp, 4 speaker-level, 1 optical SPDIF
  • 8 preamp outputs (4 volts)
  • channel settings can be separate or linked together
  • time alignment in 7 mm increments
  • 30-band graphic EQ with fine tuning
  • 1-band parametric EQ
  • adjustable high- and low-pass filters (20-20,480 Hz)
  • selectable slopes (6, 12, 18, 24, 30 dB/octave)
  • selectable filter characteristics
    Butterworth: sharp transition, suitable for most applications
  • Bessel: gradual transition, suitable for smooth speakers, but not subs
  • Linkwitz: recommended for high-end speakers only, not subs
  • Chebyshev: very sharp transition, useful as high-pass for tweeters or low-pass for subs
  • Self-Define: selectable Q-Factor, 12 dB/octave slope only
[*]adjustable Q-Factor in Self-Define mode (0.2-2.0) increases signal at crossover point
[*]phase adjustment: switchable 0/180 degrees on front and rear channels, adjustable 0 to 360 degrees on sub channels in 22.5-degree increments
[*]includes 57" USB cable
[*]optional micro SD memory card for saving and applying settings (sold separately)
[*]plug and play input from select factory radios with EPC5 Easy Plug Cable and a Helix vehicle-specific harness (sold separately)
[*]dimensions: 5-15/16"W x 1-11/16"H x 6-15/16"D
ricebowl
ricebowl
, location, location...
ricebowl
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
