Teezy 10+ year member
I wanted to know if it was anyway i could get or close to 150 db I would like to know what sub's would take this and the type of amp? ill say my budget is 700-1000.
thishow close is close to you? for 700-1000$ not sure might be able to depends on setup.. what its going in.. need a lot more info.. There is people doing 140's under 700$ but like I said you need to be more specific on everything.
Yeah for 150 it will be really hard to do period for 700$, even with everything used.. Everything I have is used and I was prolly barely breaking the 140's and was right around 700$ in eq. maybe a little less but not much.. 150's is reachable but that would be some killer deals to get all the eq to do that with.700$ budget and I'm guessing you will need wiring and head unit also? Your only hope is to get 8 or 10 of the cheapest 12's you can find and say a 1500W audiopipe amp, 50$ wiring kit, 50$ head unit with only RCA outs for a sub, and use the cheapest 3/4" plywood you can find for the box
