Hello Subwoofer idea help budget
Hello my name is Michael and I am rebuilding my dads box for his truck.
I am also giving him my old amp mate to his amp
His current setup is 2 12 crunch gpv ground pounders >boo
My idea for his box is 2 10s sealed and 1 12 ported in f350 crew cab
2 2000watt crunch 1ch amps.
so far power acustik gothic series 170$ is the only idea iv got 200$ is my budget on subs.
mabey someone has a better idea.....amps are crunch so 1000 rms is more like 450-800 ish.
Hello my name is Michael and I am rebuilding my dads box for his truck.I am also giving him my old amp mate to his amp
I hope you mean 2 10's or 1 12.
phase is not a big deal for me to get right and he will not just go 10s and his current 12s are rubing but in the middle they dont rub still power acustik is only idea here 2000 on 2 10s 2000 on 1 12
Out of phase = less loud. Why waste your money?
Hate to break it to you but PA stuff is overrated as hell
You come here asking for advice but won't take any of it. Even the most common basic tips such as DO NOT MIX SUBWOOFERS.
Honestly an Sa 12 in a 1.7-2.0 cu ft box @ 32-35hz on 600-1000w would probably do the trick...
three 10's would definitely be a better option than mixing 10/12.
However - with 3 subs you're almost required to use a mono amp as you're going to end up at either 2.7 or 1.3 ohms. Two cheap 2ch's won't match up well at all.
Sounds like your pops is lost in the 80's.
Ol' dude's gotta get with the program.
they are 1 ohm stable mono amps and iv been looking at my box 3 10s/3 12s/or 4 10s.. its a 4 door f350 and there front firing...what will work the best in that setup
I
Go with the 4 10's...2 on each amp at 1 ohm. Using 3 won't work well unless you can strap those amps and run them at 2.7. Or do just 2 10's/12's, one on each amp.
It's always leaned that direction. Not sure how cheap you can really get anything done these days. Deadening and custom mounting...
10
Welcome man. I myself have enjoyed this Hobby for many years as well. Nothing like some great tunes and getting them to sound good in a vehicle...
https://www.ctsounds.com/collections/ct-series-amplifiers/products/ct-150-4d Great 4ch amp. Id look at some Polk DB and even MMseries components...
I only have 1 jeep left now my old Comache ..to pull my black Ford out if it gets stuck ....
6
mjstutter12
toledo,oh
mjstutter12
Decebal
    Jun 10, 2024
Decebal
    Jun 10, 2024
