Help! 2 sundown audio sa8 v2 d4 with a sundown sae 1000d mono
  • 4
Take a sub, wire the two coils together with a piece of cable. Positive to pos and negative to neg. then take coil ones pos and bring it to the amp then take coil twos negative and run it to the amp.
That presents a 2ohm load, rinse and repeat you have two 2ohm loads on parallel at the amp for 1ohm. You heard me right use all 4speaker posts on the amp. Both sets of pos and negative are ran together within the amp. Basically it splices the subs together for you
Thanks brotha! So you saying run parallel and use the 2 channels on the amp? How would that be wired?
Some of the NVX stuff seems alright, but the amps, especially the higher end ones, they seem suspect and sometimes show stats that straight up say...
13
5K
Here’s another idea I was thinking of. I’m doing a single 12 in the center of the box just for aesthetics I was wanting ports on the sides of the...
Padre619
Padre619
San Diego, CA
Padre619
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
