Help 95 Crown Vic Won't crank when gets hot!
Here these past months my 95 ford crown vic police interceptor has been giving me issues stranding me and stuff. My car wont crank, turn over, nothing. Until it cools down then it will crank like nothing is wrong. I've replaced the starter solenoid and the ignition switch. Got a brand new battery and everything and we can't seem to figure out what's wrong. Does anyone have any ideas?
I've searched there and got nothing. I've tried everything pretty much just last thing replace the starter..because I've replaced the relays, solenoid, ignition switch, everything
Ok, so you join a random car audio forum to ask a question about fixing your car? This makes no f'n sense.
Anyways, make a thread over at .net descibing your problem and what you've replaced already. They'll help you.
483
535
564
Katy Fincannon
Katy Fincannon
Cleveland, Georgia, United States
akheathen
