Help Adjusting New System
  • 3
Robpevfai
I just installed my first system in a 2001 Chevy Tahoe. For a headunit I picked up the Kenwood KDC-BT558U. Along with a set of Infinity primus pr6500cs for just the front. I also have a single Image Dynamics ID12 D2 V.3 in a sealed 1.5 cu ft enclosure. All powered by a Precision Power PPI P900.4.
I have two of the channels bridged for the sub. After finishing the install the sub just dosnt sound very loud and am a bit confused with all the adjustments on the side of the amp. Could somebody help me set this and get my system sounding better. Let me know if you need anymore information. Thanks, Jeff
Here are some pics of the amp i think i have it wired correctly.
Thank you for your time. So on the rear side have the lpf on x1 and hpf on x10. And turn the lpf to the counter but not all the way. Where would i set the hdf. Sorry for all of my questions I am just a little confused and want to get this sounding good. Thanks for the help.
Thanks scott for the clarification; that is simple enough was just not sure. CSCStang I will set the sub to 80 and the front to 100 and try that out. So whatever button is pressed out is the setting it activates and what about the switch in the middle it has 4ch and stereo? It seems as if when in 4ch the sub dosnt work but in stereo it does.
Got it figured out! Thankfully a friend just found out about KunKonceptz UBT-20 terminal adapters that allow multiple connections to my type 94...
504
Turn the volume completely down and operate ot normally. This is to see if it is the built in amplifier that is shutting down. If the radio does...
That would be a function of the harness, not the HU, I think. Have you looked into a Maestro or iData interface? i would check with crutchfield...
12
542
Dammned good speakers. Just pass up the CL series,and you will be pleased with CDT speakers. I still enjoy all mine. Polk MM series and Infinity...
4
575
Robpevfai
Robpevfai
United States
Robpevfai
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
