Help choosing Amp
I am having trouble deciding what amp direction to go in. The subs i am using are a pair of Sundown x8's. These are the 3 amplifiers i am considering .
Sundown SAE-1500D
CTsounds 1400.1d
Car audio Bargin cab1600.1
What do you guys think?
Is money not a problem? If not I would choose the Sundown. If money is a problem it would be the cab
Sent from my SM-N950U using Tapatalk
I thought the Sundown 1500 was what you had?.. if I had the means I'd go with more power if I could always, seems like whatever I got is never enough eventually... lol... that 2k Sundown looks nice.
Sundown SAE-1500D
CTsounds 1400.1d
you could get that 2k. no ct sounds.. xtr 1500 tested over 2100rms so not bad but not as efficient as others.. before you spend $400 on china sundown amp u could get wolfram 1500 big blank tested $279 or for $249 you could get new soundqubed 2250 bigblank also tested, or the 1250 if you think that's enough power.. https://www.wolframaudio.com/collections/w-series-monoblock-amplifiers/products/w-1500-1 https://soundqubed.com/product/s1-2250/
Shredder,
Yes i had the 1500 and sold it to a buddy for his system. Now i am looking for something different. I think i am leaning towards the soundqubed.
Not at all, amplifiers have gain control to attenuate the output to safe levels.
6
I've moved this post to installations. Can't work out how to delete it here.
well, thats kind of an open ended question....., you can do 2500rms@1ohm, or you can do a pair of 1k-1200rms@2ohms. just have to know the amp...
5
If you're shopping in the 10 cents per watt and under department you should probably expect dubious designs and third world build quality from...
17
ROBL3870
ROBL3870
ALBANY NY
ROBL3870
