Help choosing an amp
  • 2
With those amps, you will not be able to go active...as far as I know. I am thinking of going active and was told that I need a dedicated amplifier channel for each driver. Thus, you would need a four channel amplifier. Personally, I like Arc Audio and you can get a new Xdi 804 for under $200 on Ebay. It is 4 channels, 85 watts RMS at 4ohms, and now you can go active if so desired.
Not at all, amplifiers have gain control to attenuate the output to safe levels.
6
I've moved this post to installations. Can't work out how to delete it here.
well, thats kind of an open ended question....., you can do 2500rms@1ohm, or you can do a pair of 1k-1200rms@2ohms. just have to know the amp...
5
If you're shopping in the 10 cents per watt and under department you should probably expect dubious designs and third world build quality from...
17
blackpanda1992
salisbury MD
dsw1204
Dylan27
    May 18, 2024
Dylan27
    May 18, 2024
