Help confirm or debunk my choice, which 10" for my application... RE, FI, ID, what?
  • 3
stockwes
20
Portland
Ok, i am putting in a system that is going to be geared toward SQ. The top end will be a JL Audio 450/4 and ID CTX65CS's. This stuff is allready purchased. For the sub amp i have a Concept 1200D. It is crappy but its what i have. I am planning on upgradeing later on but it will have to work for now. It puts out 1200@1ohm. I want to go with 10's and a sealed enclosure as in my experience, this tends to sound better in a sq install and i have limited space. These will be going in the trunk of an 08 Civic and with how i want to lay out the trunk i can get about 1ft^3 per sub, however i would like to stay at like .75ft^3. They will be installed in the rear of the trunk on each side behind the wheel well. I have budgeted up to $400 but would like to stay under if possible.
Here is my specs in an easier to read format
I have 1200 watts at 1 ohm
I have up to 1 cube for each woofer
I want two 10" woofers
It is a SQ geared install, mostly rock/metal will be played
What would you guys recomend? My first instinct tells me to go with 2 RE SE10D4's. I have liked RE products in the past and i really like the look. My readings have also led me to the Fi Q10 however i dont know much about it and it might be a little out of my price. Please send me in a direction or tell me the se's are a good choice. Thanks for reading
if you have 1 cubic per sub and that much power can i steer you towards the IDQ 12 either v3 or v2 will work. they sound awesome in that size enclosure. and i think woofers has the IDQ12v2 on sale
Got it figured out! Thankfully a friend just found out about KunKonceptz UBT-20 terminal adapters that allow multiple connections to my type 94...
475
Turn the volume completely down and operate ot normally. This is to see if it is the built in amplifier that is shutting down. If the radio does...
That would be a function of the harness, not the HU, I think. Have you looked into a Maestro or iData interface? i would check with crutchfield...
12
533
Dammned good speakers. Just pass up the CL series,and you will be pleased with CDT speakers. I still enjoy all mine. Polk MM series and Infinity...
4
564
stockwes
stockwes
Portland
mclerico83
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
