Help deciding on a few things
  • 1
xavier613
nj
I have a 99 Durango RT with the Infinity setup in it now. Downgraded from a much nicer vehicle to pay off student loans, and while im stuck in this slow tank for the time being i figure ill at least enjoy what i can lol.
That being said I would consider myself a noob with this stuff, Hence coming to you for advice. I have replaced the head unit in the truck already and done the big 3 wiring upgrade because i knew what to do there. Picking the rest is where i need help.
Head unit is an Alpine CDE-153BT
Truck has 6.5's and tweeters in the front doors and I was looking at getting a set of Image Dynamics CTX65CS for the front doors.
Rear doors have 6.5s as well, not sure what the best bet would be for them.
Subwoofer I was looking at a Soundqubed (audioque) HDC3.112
-(Need help with what to do as far as a box goes for this also)
Need suggestions/ opinions on the amplifiers to go with and if you would change anything to be comparable to what I have picked. I dont need anything crazy crazy loud but i definitely want very little to no distortion. As far as price options go, look at the level of equipment i have chosen and base it around that... Im not sure if these hifonics amps would work or if I should go with a better brand etc, and im open to purchasing used as well.
Thank you in advance for any help
They are good at the boom. Hard pounding lowend but lack at the upper notes. If you have a strong midbass setup they will blend fine. Buuut.. for...
13
Got it figured out! Thankfully a friend just found out about KunKonceptz UBT-20 terminal adapters that allow multiple connections to my type 94...
322
Turn the volume completely down and operate ot normally. This is to see if it is the built in amplifier that is shutting down. If the radio does...
That would be a function of the harness, not the HU, I think. Have you looked into a Maestro or iData interface? i would check with crutchfield...
12
500
Dammned good speakers. Just pass up the CL series,and you will be pleased with CDT speakers. I still enjoy all mine. Polk MM series and Infinity...
4
502
xavier613
xavier613
nj
xavier613
Dylan27
    Jun 5, 2024
HandsomeSteve
    Jun 5, 2024
