Help designing a box for a soundqubed 15"
well if it was me i would save that hundred and get another 12. its a pretty big step down from a 15 to a 12. but u could save alot of space going that route and that's not saying the 1 12 won't get u were u want. but once u hear 1 ur gonna want 2 then 4 so on and so forth. this hobby is worse than crack.
haha I know what your sayen man. Well thanks for all the advice!!
Sorry if I am being stupid or something but this is my first box! So ur saying I cant change the port area? and 3.5 cubes isn't the lowest recommended box volume, 3 cubes is
I'm saying a larger box will get you more output and you should use the manufacturer recommended specs for volume and port size. They don't just pull those box specs out of their arse, they print them because that's what those woofers are designed to use as an enclosure.
I want to try my hand at a ported box for one IDQ12. I built a sealed box a few years ago and it sounds good but I want to see how ported...
190
464
456
bassinmytruck
bassinmytruck
Wichita, KS
hispls
