help hooking up 99 camaro power door locks
  • 1
hemi=22s
I Pop Bottles
I have a 99 Camaro that does not have factory door locks (buttons anyway) but does have the factory wiring and actuators on the latch mechanism in the door
I guess it had a keyless entry system on it but I don't have the factory remote
to the factory actuators there is a tan and gray wire in door and turns into a black and black with white stripe in the door
every install guide gives guidelines to hook up to the door lock switch wires which again I don't help
Got it figured out! Thankfully a friend just found out about KunKonceptz UBT-20 terminal adapters that allow multiple connections to my type 94...
507
Turn the volume completely down and operate ot normally. This is to see if it is the built in amplifier that is shutting down. If the radio does...
That would be a function of the harness, not the HU, I think. Have you looked into a Maestro or iData interface? i would check with crutchfield...
12
543
Dammned good speakers. Just pass up the CL series,and you will be pleased with CDT speakers. I still enjoy all mine. Polk MM series and Infinity...
4
577
hemi=22s
I Pop Bottles
hemi=22s
west palm beach, fl
hemi=22s
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
