Help identifying a sub
My dad had a sub from when he was younger. It's an infinity kappa perfect 12.1 d
Does anyone know what's it worth?
Condition is everything to one of interest. Can you provide pics of the Cone/Front /Rear, and have you tested the coils to see if they are within Ohms limitations?
Pretty decent sub actually. I had one in a ported box, sounded great, but not enough output. 2 on the other hand would be real nice for a low power setup. Or even a pair sealed would be nice.
I've got one that I just can't throw away. Does anyone know if these can be rebuilt?
If you have the patience, you can definitely rebuild it. Hardest part would be to find the coil that best fits it. It may not be a common size.
Taking it apart is also time consuming if you want to re-use the cone and rubber surround. Totally worth it when the outcome looks OEM.
That is TOTALLY it! Thanks all! I couldn't find it for the life of me.
First of all you would want to verify that it works. Next, don't expect to get much out of it. There's a rather finite life expectancy on...
Reading ohms is very touchy. Stay still and measure. Both coils should read very close to each other. Around 1.8 for dual two ohm and 3.6 for dual...
10
CHOG
CarAudio.com Newbie
CHOG
Minnesota
1aespinoza
GoldCountryCA
    May 5, 2024
GoldCountryCA
    May 5, 2024
Latest topics
